Connecting and updating all user e-mails is working on our Microsoft Outlook 2007. However, when used with Exchange 2007 and Sharepoint 20, there are times that one of our users encounters a “Send/Receive” error.
This happens even if Outlook can connect and update all user e-mails. We still get the error message after the box for “Don’t show this dialog box during Send/Receive” was checked.
What causes this and how do we stop it?
Don’t show this dialog box during Send/Receive – Exchange 2007
If this is the first time it happened when you are using Microsoft Office Outlook, try restarting your computer then try it again. See if this fixes the problem after booting the machine. If it didn’t work, check the settings of the program for any accidental changes that may have applied. Check if the right port number is specified in the program and the correct smtp address is set.
You may also try reinstalling Microsoft Office Outlook to fix any missing files that affects the functionality of the application. Uninstall Microsoft Office Outlook then restart your computer when asked. If Microsoft Office Outlook is part of the Microsoft Office package you installed on your computer, remove only this feature and leave the rest of the programs installed. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your computer, use a disk utility application like PC Tools Performance Toolkit. Install Microsoft Office Outlook again then see if you are now able to use it.
