Done But With Errors On Page
When I access it, it shows that done but with errors on the page. When I further double click on this it shows that errors on this webpage may cause it to work incorrectly. How may I overcome this error?
When you get a message showing that done but with errors on the page then to resolve this you should follow the given procedure:
• Select the tools button.
• Choose Add-ons.
• Check if Google Frame is loaded or not.
• If it is present then disable it.
• Restart your IE and check if the same situation arises.
• If this isn’t the case then you should rather clear the cache.
I think the reason why you receive that error is because you are using Microsoft Internet Explorer. If you are using this browser, you need to get used to different sorts of errors appearing on the status bar. You can ignore those errors you see if the page is displayed properly. But if the page is displayed incorrectly, try using a different browser.
Try using one of the following web browsers:
