Why am I getting this unknown error using Mac Operating System says “Don’t Leave Now there’s a Demon at your Desktop”.
What does it mean?
I really unable to understand this message.
Guide me properly to fix this error.
Thanks in advance.
Quit Doom?
Don’t Leave Now there’s a Demon at your Desktop!
Doom cannot be shutdown on Mac OS
Hi Hector!
The small window that appears is not an error, the game just needs another confirmation that you want to exit, so when the window appears again, you should press the Y key on your keyboard ( Y from "yes") and then the game will close.
It's only an attempt to make you resume the game and keep playing, so don't worry.
However, if you still have problems closing the game, you can always use the keyboard shortcuts: CMD + Q or CMD + Option + Esc. Also, when you are in window mode, you can simply click the X button and that's it.
Have fun!
