DOT NET Trouble. How To Fix Framework Error While Using DOT NET?
My computer ran into framework error while trying to update the Windows. I don’t have the slightest of the idea why it did so. How to fix framework error without any hassle?
Misconfiguration of files or corrupted files can cause the DOTNET framework error. To fix the error, you can use the help of Microsoft Automated Wizard which does the most of the works easily for you. Try uninstalling the program and repairing the DOTNET framework to the original state. This manual repair can be more effective. After doing the repairs, you can reboot the computer.
If you are doing or updating something on your computer and you encounter a .NET-related error, try to uninstall and reinstall the affected version of Microsoft .NET Framework. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select the problematic Microsoft .NET Framework and click “Uninstall”. Follow the normal uninstall process.
When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, download and install the required Microsoft .NET Framework from the following:
