Double click in the short cut on Photoshop icon, alert message coming
Hi experts,
when I am trying to double click in the short cut on Photoshop icon, I get this alert message.
Thanks in advance.
Hi experts,
Thanks in advance.
The main reason to your problem may be the following.
1. The reference address of the shortcut mat have been replaced,
2. The other reason may be the Photoshop set up have been replaced or relocated.
3. May be the drive in which your Photoshop has been installed is locked.
4. Check for the following reasons and make sure that the shortcut is correctly referred to the installation location.
Thank you.
Hi Berthapearll,
Your Photoshop shortcut link is missed the path of original Photoshop icon.
First follow that steps to again make the new shortcut for Photoshop:
this may help you. Thanks!
I suggest that you have to uninstall your Photoshop.
1. Click “Start” button
2. Go to control panel
3. Below the word “Programs” click uninstall a program
4. Go and find Photoshop that you have installed
5. Right click and uninstall it
I would like you to know about the compatibility issue, you are encountering this kind of error because there is a possibility that your operating system is not compatible with your Photoshop.
Search in Google: latest version of Photoshop that is compatible (to your current Operating system).
Download and install.
I hope this will help you.
Hello Bertha,
Where is the Photoshop icon that you're trying to copy? I'm guessing it should be in a USB drive or external hard disk. The problem you are getting could be because of the following reasons:
Carl
