Doubt on installing android nokia x6
I heard that android can be installed on Nokia x6. Is it possible to install android in Nokia? If can then help me through installing android Nokia x6.
Searching for answers online will reveal that people have mixed opinions as to whether you can install android on a Nokia unit such as x6. Technically speaking, it is possible. However, this is not something that can be done simply or that can be done by anyone. There's a lot of complex involved, such as downloading the android firmware, flashing custom roms, etc.
But for knowledge's sake, yes that is possible. But if you are happy enough on your existing x6, best is to leave it as it, and get a certified android-capable phone instead.
