olivia.bha
70 points
Posted on - 06/03/2012
I am now looking to buy a Sony Xperia Solo and I have some serious doubts. The dealer says it can record HD videos, but it only has a 5MP camera. And I don't really know about its RAM and processor range. My dealer says its cost is about RS 21,500, is that true? Can I trust my dealer?
Doubts about Sony Xperia sola
Hi!
You can view reviews about it at https://www.phonearena.com/reviews/Sony-Xperia-sola-Review_id3042.
The LCD display on the Xperia sola measures 3.7 inches in diagonal and has a resolution of 480 by 854 pixels. It can play HD movies, but to record movies with HD quality you will require to download a software for it. Hope this helps you. Goodluck!
The Sony Experia Sola according to GSMArena records video at 720p @30fps with continuous autofocus. 720p means that it will record video of up to 1280 pixels width and 720 pixels height. This is a high definition standard. So yes, the Experia sola can record video in HD even though the camera is 5MP.
The Experia sola has a dual core 1GHZ cortex A9 processor which is really powerful and RAM of 512MB. Looking at the specifications of this phone, RS 21500 sounds about the right price for this phone.
I hope this helps.
