Bersh Roman
30 points
Posted on - 05/10/2013
HI guys,
I am looking for cpu cooling and fan control software for my pc. This software should be able to perform a diagnostic test of my pc and provide me with accurate statistics on the condition of my pc. This software should also be able to adjust my fan speed in order to cool my cpu according to the level of usage that it is undergoing.
If anyone can provide a download fan cooling for pc software please reply to this post.
Down load fan cooling for pc
Hello Bersh,
You can use Speedfan software for your case. It is a software that monitors your computer’s temperature and other activities on your computer. It is good and one of the most popular.Â
Hello Bersh,
According to your needs, I suggest to download CPU Cool 8.1.0 because it is what you are seeking for.
CPUCool 8.1.0 consists of:
1) S.M.A.R.T(Self Monitoring And Reporting Technology) -you will be able to write values, read disk and even monitor the HDD temperature.
2) Track several hard disk details, processor core temperatures,fan speed and voltages.
Motherboard models that CPUCool 8.1.0 supports:
1) Chipsets from AMD
2) Intel
3) VIA ALI or SIS 5595
To download CPU Cool 8.1.0 just simply click
