Download Accelerator Plus Premium related question
Kevin Molina 10 points N/APosted on - 06/11/2012
Hi there everyone! I do not have much idea about the reliability of the new release of the Download Accelerator Plus Premium. Is there anyone who can provide me information on this software? Thanks in advance.
New version of Download Accelerator plus premium is more reliable than its previous version. This is worlds leading download manger and allows you to download with 300% faster, reliable, resume and error recovery support. It also searches for mirror sites that most effectively serve alternates to your downloads. Here are some features
– Preview pane – provides forll preview downloads of Music, video and miscelleneous files
– Download list – Advanced management of downloads queues, priorities and statuses
– File Information pane – Advanced information of downloaded files and sources
– Completed downloads list – Separate list of completed downloads
– DAP Drive integration – Save downloads and Upload files to DAP Drive web storage
– Media Center Tab – Conveniently manage your media files
– Superior Usability – New interface with flexible design options
– Integrates with all browsers – Internet Explorer, Netscape, Opera, Mozilla/Firefox
Aside from the download manager you are using, you can also try Free Download Manager. Unlike your download manager, Free Download Manager is free. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It also works on Mac with OS X 10.9 Mavericks and higher. For Windows XP and Windows Vista, you can download Free Download Manager 3.9.7 Lite.
For Windows 7, Windows 8.x, and Windows 10, you can download Free Download Manager 5.1.32. Among its features include:
BitTorrent support allowing users to download files using the BitTorrent protocol.
Enhanced audio and video files support giving the users the freedom to preview audio and video files before the download completes and convert the file after it gets downloaded.
Download acceleration – Free Download Manager splits the file to be downloaded into several sections and downloads them simultaneously allowing you to use any type of connection at the maximum available speed.
Resume broken downloads – when the download gets interrupted, Free Download Manager allows you to resume from where it was interrupted.
1....
