Download And Install Adobe Acrobat Reader For PC
What is an Adobe Reader? How to download and install adobe acrobat reader for pc? What is the size of the software?
Adobe Reader is used for viewing, create, edit, print and manage files in Portable Document Format (PDF). The size of the software is 71.24 MB. It is available for both desktop and mobile platform. You can download the software from HERE. After downloading it, install it by double-clicking on the downloaded file and install it your desired driver.
Adobe Reader or Adobe Acrobat Reader is free software for viewing, annotating, and printing PDF files developed by Adobe. If you have PDF files or someone sent you these files, you need an application like Adobe Acrobat Reader to open the files. It is the free global standard for reliably viewing, commenting, and printing PDF documents.
If you don’t have it yet, you can download the latest Adobe Acrobat Reader DC from the Adobe website. It supports Windows XP Service Pack 2 (64-bit only), Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. For servers, it supports Windows Server 2003, Windows Server 2008, Windows Server 2008 R2, and Windows Server 2012.
An alternative to Adobe Acrobat Reader is Foxit Reader.
Notifications
