Download and install driver for Connecting galaxy tab on MAC
Hi Sandeep,
Just Go to below link and enter your product name or model number and download the manual and drivers related to your product.
Link: https://www.samsung.com/us/support/downloads/
After download the driver for mac, Do settings in your mac PC.
1. Go to Settings > Wireless & Network > USB and select Mass Storage
2. Galaxy tab USB to your Mac connect it. Drive for it will be seen and you can start moving your files.
Thank You
Hi Sandeep,
There are many software for doing so.I would suggest you this-https://www.android.com/filetransfer/Â just follow the link and download the file.You will get a automatic process instruction.Follow this instructions and everything will be set.Then you connect with your tab.
for more information go- Samsung Hub
Thank you.Feel free on Techyv.
