A Cameron
Posted on - 10/13/2016
Printers are required to bring the data from computer to paper. Lexmark is one of the popular printers. It has all-in-one software to make our work easier. How to download and install lexmark all in one center?
Download And Install Lexmark All In One Center.
Download the All-in-one software from www.lexmark.com or insert the CD.
 Installation:
1)Â Â Â Â Â USING THE CD
·        Close all the applications.
·        Insert the CD in CDROM. 4300 series installer icon is displayed on the desktop screen.
·        Double-click on it.
·        From the box displayed, click on Install.
·        Press on continue to start the installation process.
·        Read the instruction and continue.
·        Accept the agree license.
·        Select a location for the software. Then click on Continue.
·        Press install.
·        When prompted type a password and then click OK.
·        The folder will be created on the desktop.
·        FROM THE WEBSITE
·        Go to www.lexmark.com
·        From the home page, select drivers and downloads.
·        Go through the menu selection.
·        Select your device and the OS.
·        Press on Download now.
·        Confirmation after the download will prompt. Click on Continue.
·        Follow the onscreen instructions.
·        Choose a language according to your preference and click Continue.
·        Choose the country.
·        Follow the instruction to select the printer.
·        After the installation is complete, register yourself.
·        Click on Finished.
·        Press on close.
