Download and Install Process of IBM Server LAN
Dear user,
IBM has currently released network driver which resolves and improves your computer's stability and restores communication with all Networks. You have to download IBM Driver Installer for this, here is the installation process:
1) Download IBM Driver Installer.
2) Click run or save as.
3) Now follow the directions given on screen for further installation progress.
Hope this will help you.
Thank you.
Hi Joyce,
A foremost thing that you need to do is to have IBM server software. Once you procure this software then you can do the following to install the same on our system.
Read through the following text file on the web to find your appropriate installation procedure according to the hardware your system is having.
http://download.boulder.ibm.com/ibmdl/pub/systems/support/system_x/31r2561.txt
Hope this helps.
Thanks
Baker
