Devinuhler
Posted on - 03/12/2013
How will I remove download antivirus extra? I have just installed an Antivirus on my PC, as I scan a list of infections detected and a message pops up saying I need to purchase some program. I reckon it’s all fake Viruses. How will I remove it?
Download antivirus extra how to remove fake virus
Thanks for the questions. You can use several antivirus software available in the market like Kaspersky Internet security, avast Internet security, Norton internet security etc. You can remove this virus by scanning in your full system. After full scan, when it detects some infected files, you have to delete those files to delete virus if this viruses are generally not removed. Have a good day.
It's common a feature for using free antivirus. The best solution can be used premium antivirus like licensed purchased antivirus. There is no alternative. In fact, you also have to careful about the branded antivirus like Kaspersky, Norton, Bit-defender etc. Though they can be expensive, you must need to use it to ensure 100% protection of your PC. You can try one of these brand. Best of luck.
Hello Devinuhler,
Hope you are fine. However, there many antivirus in the market like Avast, Avg. The most interesting thing is that you may check the trial versions and then compare yourself, which one is better. Now you can purchase the full version from the internet or buy a CD from the market. At first, install your antivirus on your computer. Then register your antivirus with license key (if any). Now you can remove viruses from your computer by following the steps.
Click on scan full system
Now it will start scanning your computer automatically.
It will take time to complete scanning process. After the completion of scanning a new pop window will show you how many viruses it has detected.
Now click on Delete all and then the antivirus will delete all detected viruses.
Download avast
Download Avg
Hope you will get your answer.
