Download a free flash player for mid tablet
I accidentally deleted the adobe flash player from my Coby Kyros MID 7042. How can I download a free flash player for mid tablet? Can you direct me to the correct site?
To download ADOBE FLASH player Please log on to:
http://www.adobe.com/products/flashplayer.html
There you can see adobe products according to your system. First see is there any product according to your system. Then select the version and click to download link. Hope you will find your desired product.
Here I have added a screenshot of that.
You can download free flash player for mid tablet. It is easy to download.
Quick Flash player 1.3: It is an application that enables you to play SWF files and convert them into EXE files. The program will work properly and can play your files in full screen. The link is given below to download.
http://www.2000shareware.com/info/quick-flash-player/177140/
Just click on ‘’Download’’.
There’s actually no problem even if you accidentally deleted Adobe Flash Player on your Android tablet because you can still be able to install it back. Your Coby MID7042 tablet runs on Android 4.0 Ice Cream Sandwich. This means you need to install Adobe Flash Player for Android 4.0. Here’s how to manually install Adobe Flash Player on your tablet.
First, connect your tablet to a Wi-Fi network or turn on data to connect it to the internet. Next, go to Settings, Security, then select Unknown Sources, and then tap OK. Exit Settings then start your web browser. Download Adobe Flash Player 11.1 for Android 4.0 (11.1.115.81). This is currently the latest version compatible with Android 4.0 Ice Cream Sandwich.
Close the web browser once the download is complete then open the Notifications and then tap “install_flash_player.apk”. Tap Install when you are prompted. Tap Done when the installation is complete. And that’s it. Adobe Flash Player is now installed back on your tablet.
