Download fruits images with names in a simple way
Hi everyone,
I am doing an assignment where I need to download fruits images with names. But I find it in a very tough way, can anyone suggest me some simple way of downloading it?
Best Answer by Franklin Alejo
Answered By 0 points N/A #190244
Hello, Edith,
There is a quick technique for searching images. First of all, go to the "Google Image". In the search box, type what image you like to search. For example: write "fruits images" and click on the search button. I am happy to say that you must get a series of qualitative image list. I think it will remove your stress.
Best of luck!
Answered By 0 points N/A #190245
Hello Edith J Tucker,
From what I understood you are asking for a web page where you can find a list of fruits, illustrated with pictures, and below you may find the name of each fruit. If understood correctly, please refer to the below URL.
It will forward you to the "fruits" category, and there you will find platy of fruits.
Choose the picture you want, right click on it and then select "save as".
