Download game generals Should be used as ‘KeyWords’
How do you download games from, I mean tell me a sight from which you can download a games generally?
Are you actually interested in downloading "Game of the Generals"? I personally, enjoy playing this game, Command and Conquer: Zero Hour. This game is from EA (Electronic Arts). You might want to take a look at the latest game offerings from EA including Game of the Generals. Here's the website you could check on: www.ea.com/
Hope that helps!
Hi Asheley,
Most of my game installers came from the net. And I always use Google to download them. Google is the starting line, because after the Google gives you the result, you will be directed to different sites. This is how my technique of doing it.
In the Google search bar, I always put my keywords inside a double quotation mark.
sample "Counter Strike Source"
Hope it helps.
It is very simple to download the games from the best downloading sites, you can simply search the "free download games" or Free download for PC/Mobile" or Download Game Name for free etc., simple keyword after the searched results you are getting the number of websites.
I am suggesting you the best site to download games which I mostly use.
