Download ghost program to automate repetitive tasks
Hi guys, I have been doing a lot of repetitive tasks on my computer lately. Is there a way to control a pc with a ghost program that can automate these tasks? Thanks.
Hi
You can use Ghost control software if you are fed up with doing repetitive task ,its allows you to record keyboards inputs and mouse inputs while performing a task .Once its recorded ,actions are saved in Ghost control job ,when you wish to work, replay job its fast and easy and user friendly software .you can download it Ghost control software from given below link.
http://download.cnet.com/Ghost-Control/3000-2084_4-10350444.html
Thanks
McNabb
Hello McLeod,
Hope you are fine.
Yes there is a way to control your PC with Ghost control software, but there are many other programs that can meet up your needs. As for example” Qotizer 1.1 build 37”.
This software helps you control your everyday repetitive tasks automatically. All your actions are saved in this software and almost everything from disk operations to internet related tasks are automated by it. Click here to get Qotizer .
Here you will find more software that can meet up your need. Just go and download them.
Hope you will get your answer.
Notifications
