ted hitz
20 points
Posted on - 02/26/2013
I come to know that advent Vega now supports flash player. I need advent flash player download. From where I can advent flash player download? What are the requirement and procedure? Please help me.
Download Link and Procedure for Advent Vega Flash Player
Hi Ted,
You can install the flash player by updating your software from 10.9 or lower to 10.10. It includes updates, improving screen performance, minor bug fixes, and remove touch panel utility. Go visit this site http://www.myadventvega.co.uk/ to download the update with adobe flash player 10.1 with it. There are no certain requirements for this update and installation.
Hope this will help you out.
Hello Devon,
Yes, Advent Vega supports flash player.
You can download it from here.
You able to download it with the Adobe flash player 10.1.
There are no certain restrictions to download and install it.
Because it is very easy to download. After ending download just installing it enjoy the Advent Vega.
That’s all for you. Thanks.
Johnny Mrmarshall.
