frank logan
10 points
Posted on - 02/04/2013
Hi!Â
I want to download AVI editor for Mac OS. Can somebody help find me one reliable software and link? Would really appreciate any suggestion and really need to get with this.
Download link of AVI editor for Mac OS
Hello Frank,
AVI Editor for Mac. Best professional software for this purpose. You can find more on the web. Using AVI Editor you can control brightness, contrast and can trim video even you can submerge the files also. Here is the link. Read the manual carefully before use.
Dear Frank Logan,
I will recommend you a few software for you, that are good, reliable and have high ratings.
1. iOrgSoft Video editor for Mac – allows you to convert, create and edit videos on your Mac, It can read, convert and write videos at many file types (including HD) (
download here).
2. Total Video Converter – a great multi format audio and video converter that converts many formats, it's a great amr convert for Mac (
download here).
3. Avidemux – Avidemux is a freeware video editor designed for simple encoding. For those who aren't interested in the Apple software, Avidemux is one best option (
download here).
I think this will help, good luck!
Regards!
Nathan H Underwood
