Download link of quizcreator software
Hello!
We are dealing with online quizzes, tests, surveys and assessments. Actually, we have got some software but none of them are not matured enough.
Can anyone help me to give a reliable download link of quiz creator software? I would like to get tutorial also.
Best Answer by Drake Vivian
Answered By 30 points N/A #173826
Hi there Jose V Lau,
I don't know what software you've tried, so I'll give you a few that are reliable, stable and professional.
My first advice would be to try the WonderShare QuizCreator. It is a simple yet powerful software with user friendly interface and simple wizard that will guide you through the whole process of the quiz creation. Once you've installed it, just run the wizard and follow the instructions. You can find, review and download the trial on the following link: https://www.wondershare.com/pro/quizcreator.html.
Another software I'd recommend you is the ProQuiz. Just as the previously mentioned software, this one is too simple, user friendly and with plenty of options that will make your quiz look wonderful and professional. For all the details check the http://proquiz.softon.org/.
Best regards,
Drake Vivian
Answered By 25 points N/A #173827
Hi Jose V Lau,
I think you have already got your answer from Drake Vivian. I have personally recommended you to go to Pro Quiz.
Because it is open source and free of cost. I am also giving you a YouTube video tutorial for ProQuiz.
Think it will help you.
