Download link for Teamviewer for CentOS
Hello! I am having a dual OS in my laptop and I'm currently using CentOS. My friend from another country is using CentOS too and we're actually working on a program. He's having problems with his laptop and he is unfamiliar with it so I thought of Teamviewer for CentOS, are there any? If so, please post the download link. Thanks!
Answered By 0 points N/A #167181
Hi Campbell Parker,
Team viewer can be installed in Cent OS.
First, you need to download the corresponding rpm for Cent OS from their site
https://www.teamviewer.com/en/download/linux/
You can install using graphical installer as well as command line.
If you are installing using Graphical Installer, you only need to double click the rpm file.
If you are using command line, use either of the below commands.
yum install teamviewer_linux.rpm
or
rpm -i teamviewer_linux.rpm
yum install is most preferred because it will install any missing dependencies also. If yum is complaining about any public key missing, you can download it from here
Hope it helps.
