fabion cole
20 points
Posted on - 01/27/2013
Greetings people! I have searched for digital media player software for Windows PC and came across Zune. I want to make sure to download an exact Zune 32 bit full for my PC so it won’t be a waste of time downloading the wrong one. Please comment below the link’s. Thanks!
Download link for Zune 32 bit full
Hi Fabion,
I can surely give you a reliable link to download Zune software for your digital media storage and application for smooth running.
Navigate the following Microsoft web link and download your appropriate 32 bit Zune application.
http://www.microsoft.com/en-in/download/details.aspx?id=27163
This software would also help you to create synchronization between your digital media library and windows handset device to add-on its functionality.
Hope this helps.
Thanks
Baker
Hello
As it is a product of Microsoft You can download an exact Zune 32 bit full to your PC from the official website of Microsoft.
There are some requirements for installing Zune.
1. Your O.S should be windows xp sp3/vista/7
2. 1GB RAM for 32-bit O.S
Hope you got some need full from above post.
Regards
Hock Clotildec.
