Download Links for Infrared Drivers in Windows 7
Hello experts,
Where to locate the built in windows 7 32 bit infrared drivers? I would like to get an update for all the drivers especially with the infrared.  For an infrared is very important when It comes to sending of information or some specific files. I hope you can give me an answer.
Thank you.
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #174511
Hi Mellisa Wright,
Just update all of your drivers using Windows update, just turn on the automatic update and connect to the internet, your windows will automatically update your IR driver and all of the other drivers of your system. You may also update it manually using device manager. You can go there by right clicking my computer, properties, device manager, and then right click your infrared device, properties then select the driver tab and select update driver.
Answered By 0 points N/A #174510
Hi
I understand your concern. I will help you to locate Windows 7 IR driver. You can look for IR drivers in support area of your PC manufacturer's website. Just locate your model and you will get the drivers. And if that does not work, then download the drivers from http://whp-aus2.cold.extweb.hp.com/pub/softpaq/sp41501-42000/sp41705.exe. This should work perfectly.
