Download Links for Toolbar Skins Software in Windows
I have a lil' prob on changing my skins toolbar but don't know where to get the toolbar skins software. Is there anyone who knows where to get the toolbar skins in Windows?
Hi Jose,
I hope this may help you, XP Explorer Toolbar Skin 1.0. Here is the site http://www.softpedia.com/get/Tweak/System-Tweak/XP-Explorer-Toolbar-Skin.shtml#download Just click the download icon. If the download complete just run the application. After that browse for the image. The Image must be in bitmap format and with size of 900×85 Pixel. After selecting the image click SET. Restart the window explorer and you will see that the command bars are full of images you had selected.
There are many sites where you will be able to find out awesome and cool toolbars.
Here, in this site, you will be able to find out many awesome toolbars to customize your PC.
Also, you can try “Explorer Toolbar Editor”. It is a super software with which you can
