Mary West
30 points
Posted on - 11/25/2012
Hi
I used this software in my 32 bit XP operating system and I installed a 64 bit version. I cannot install the same software and I need a place to download vegas 9 for xp 64 bit.
Thank you
Download Links for Vegas 9 Compatible with Windows XP 64-Bit
I can provide you with some sites in order to download the Vegas latest software updated with the keygen. But there is an issue with your new OS because there is no software version in Vegas that supports the WIN XP 64 bit OS has released yet. Though you can install the software to your new OS you'll have to face with lot of errors when using the software and it will also become difficult to find solutions for those system errors.
* Therefore you do have only two options. Either you should use your older WIN XP 32 bit version OS or you'll have to upgrade to any other version of Windows except WIN XP 64 bit version.
* If you can upgrade to WIN 7 it will be more useful because the latest version works better with WIN 7. If you want to download the Sony Vegas software again to your PC free please visit the below link.
https://filehippo.com/download_sony_vegas_pro/
* The link above provides you a free version of registered software for your PC and the software is also malware free which support a secure download. Follow the instructions on the software download page above for installing it on your PC.
