Download LogMeIn Ignition for iPhone
Hi Experts,
I want to download LogMeIn Ignition for iPhone. Where can I get it? I need it badly for connecting remotely. Thanks.
Belensienna
Hi Experts,
Belensienna
Good day!
Logmein Ignition for iPhone has good reviews and ratings based from the app store. However, you might also want to try other applications that has the same function. You may try Teamviewer for iPhone. It is free and can be downloaded from the app store. You may download it from the link below.
https://www.teamviewer.com/en/download/mobile-apps/
Hope this helps. Good luck!
Hi.
You can go to LogMeIn website.
Create an account and download the trial version.
But you can also choose a subscription if you want to use it long time.
If you are using an iPhone, search it from the App Store and click install.
For users who are looking for a download of LogMeIn Ignition, unfortunately at the moment, there is no more LogMeIn Ignition because it already reached its end of life. Here’s their explanation why they shut down the application:
“Our product development efforts at LogMeIn have always centered on enabling employees and individuals to simply and securely connect to their devices, applications, and files. In an effort to focus our current product portfolio, we took Ignition’s most used features (file sharing) and built them into LogMeIn Pro and LogMeIn Central to create a complete way to connect to the content and devices you need, all in a single product experience. We also support the use of the free LogMeIn app for iOS or Android which is a feature-by-feature equivalent of LogMeIn Ignition.”
If you have a LogMeIn Ignition account, you can still access your account until April 9, 2018 while the LogMeIn Ignition application will still be available for download in the App Store until April 8, 2018. As alternative to LogMeIn Ignition, you can download the free LogMeIn app:
Use the same credentials you used to log in with LogMeIn Ignition.
