Download NET Framework 3.5 SP1 Full For Windows 7
I have started to use Windows laptops. Earlier I used to use Apple laptops. To use native Windows app I need the NET Framework 3.5 SP1 full version installed on my computer. Please help me to download it.
Answered By 0 points N/A #302602
If you want to download and install the Microsoft NET Framework 3.5 SP1 full for Windows, you have to first check the system requirements. The system requirements are as follows.
1. Minimum OS version – Windows XP, Windows Server 2003
2. Processor – 400 MHz Pentium or equivalent.
3. RAM – Minimum 256MB recommended
4. Up to 500 MB of free space required for installation.
5. Recommended resolution – 1024×768
If your computer meets this requirement you can go ahead and download the NET Framework from Microsoft’s official website.
Answered By 590495 points N/A #303150
If you need .NET Framework 3.5 SP1 then download Microsoft .NET Framework 3.5 Service Pack 1. This is the standalone installer for .NET Framework 3.5 SP1. It supports Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008. This Microsoft Windows component requires a version of the Microsoft Windows operating system to work. It will not work on other operating systems like OS X and Linux.
If you are using OS X and the program you want to use needs this component, you need to install Microsoft Windows on a virtual machine on your Mac to install it. You can use Oracle VirtualBox to create a virtual machine. It supports OS X and Microsoft Windows.
Once a virtual machine is setup, install any of the supported operating systems mentioned above on the virtual machine you created. Once the operating system is installed on the virtual machine, install .NET Framework 3.5 SP1 on the virtual machine.
