Download .NET Framework 4.30319 for Fix-It 2012
I installed Fix-it 2012 but when I was trying to run the program, it was unable to start and it says I need a .NET Framework 4.30319. Where can I get this for download?
I have found the download link that you are asking and for the download link, I found a trusted site that has the file you may check the download link.
Please download and install the file(make sure you have downloaded the file completely to avoid errors occurring) and now you can run the fix-it 2012 .net framework is very important to us almost all program requires this file autodesk, COD, GTA, windows 7 updates and other games and programs.
I hope you have a nice day and enjoy your stay with us we will provide you the help you need.
Hello Justin,
The best and easiest way to install the latest version of the .NET Framework that is needed for the proper functionality of your system is to run the windows updater on your system which will not only download the .NET Framework but it will also download the latest updates of other system files as a result it will improve the performance of the computer.
To run windows update, do the following:
Carl
Hi
According to your question there is another Techyv post which one also will be helpful for you .
Visit this link : Where To Download Net Framework 4.0 Extended?
Notifications
