Bersh Roman
30 points
Posted on - 05/03/2013
Hi guys,
I am using Adobe Photoshop CS5 and I have been having trouble with smoothing image surfaces, the current smoothing feature is not really sufficient in terms of the quality I want so I was looking at using the plugin Photoshop CS5 Kodak Gem to extend what I can do.
What I want is help on the advantages of this plugin and how to acquire it, thanks guys.
Download Plugin Photoshop cs5 kodak gem
To smooth skin surfaces you can use KODAK PROFESSIONAL GEM Airbrush Plug-In.
The advantages of this plug-in are
It smoothes skin without blurring or affecting facial-feature detail.
It balances unflattering facial highlights and shadows—smooth surfaces by reducing harsh shadows and highlights
Minimize skin imperfections and other surfaces, while fully preserving details like hair, eyelashes, eyebrows
It controls the image detail at three levels: fine, medium, and coarse.
This plug-in can be used with both 8- and 16-bit image files.
To acquire this plug-in you can download trial version, upgrade or buy  from http://www.asf.com/
Hello Roman,Â
I understand your question, and I will give you the answer that helps you. The plug-in I recommend you to use, have some attributes that can satisfy and help  you :
– It is free.
– It is secure and tested for viruses (and you can do this yourself by analyzing it with your anti-virus software)
– The plug-in name is Adobe Creative Cloud Desktop and can be downloaded from this link
Cross Bohon
