Download problem AVG antivirus help
I have needed to downloading AVG antivirus. But I do not download it . Many more times I,v trying to download this antivirus.
I know it is very good to use and it is so safety and secure antivirus. I also have downloaded it before very easily .
I need help to download AVG antivirus.
Jony
Best Answer by lee hung
Answered By 75 points N/A #87431
Hi Mickhel,
I wish you could have stated the exact kind of problem you are experiencing during the download process. Otherwise there are many sites that you can get avg antivirus without any trouble:
http://www.majorgeeks.com/files/details/avg_antivirus_free_edition.html
Try the above link, it will lead you to majorgeeks to download avg for free:
You could also prefer other sites like cnet downloads, softpedia and other download sites.
Hope this helps.
Regards.
Answered By 5 points N/A #87432
For downloading AVG Antivirus for free.
Click on https://filehippo.com/download_avg-antivirus-free/ Press download from right side (Green Icon).
Save file to your system, and after successful download run setup.
