Download RDP for Windows 7: How to enable it.
I have downloaded RDP for Windows 7. RDP stands for Remote Desktop.I want to enable it? Do I want to know how we can enable it to step by step?
After downloading RDP for Windows 7, you can enable it by following these steps:
Step 1: Double click on Windows 7.
Step 2: Select "System and Security" after opening the control panel.
Step 3: After this click on "Remote Settings".
Step 4: At the bottom of the panel there are several options for Remote Desktop. Click on " Allow connection from other computers".
Step 5: Click on "Select Users".
Step 6: Select "Add" where you can add a new user account by selecting and then click ok.
