Download Snipping Tool For Windows7.
Where to find snipping tool? Whether it is to be downloaded or is it already included in the windows7? What is the use of this tool? How to download snipping tool for Windows7?
A Snipping tool is a tool that allows the user to take screenshots and this feature is already included with:
• Windows Vista
• Windows Server 2008
• Windows7
• Windows Server 2008 R2
• Windows Home Server 2011
• Windows8
• Windows Server 2012
• Windows10 It can be used to capture, annotate, save and share the snip.
It also allows you to take screenshot of the menu and to remove the URL. Snipping tool is already present in Windows7. Go to start button and type snipping tool in search box. Click on ‘Snipping Tool’ option given in the result or Click on MyComputer, go to C drive and click on Windows. Now click on System32, here you will find Snipping tool option, click on it. Its path is
C:WindowsSystem32SnippingTool. In case you do not find it, you can download it from this site:
http://www.gutmannsoft.com/en/screenshot/capture-screenshot-lite.php
Notifications
