Download A Tool To Convert PDF To DWG Autodesk.
Asked By 220 points N/A Posted on -
Hello guys,
If I receive a Drawing in PDF Format and want to edit it using AutoCAD, then what should I do to change it in the required Format? I do not want to use an online Tool. I want to download a Software to Convert PDF to DWG Autodesk.
Answered By 0 points N/A #126004
You can open DWG Files using AutoCAD. To convert the PDF File, you can download AutoDWG PDFin PDF to DWG Converter. You will get a Trial version only.
If you want the full version, you have to purchase it. It comes in a 30-day trial version. During the test period, you will not be able to Save and Copy things on the Clipboard. You can convert Multi-page PDF Files using it.
You can choose specific pages that you want to change. I will advise you to go for it.
