Download Trial Version Of Microsoft Office
How to download the trial version of Microsoft Office from the official website of Microsoft Office? What is the maximum time duration for which we can use this trial version?
Proceed as per the instructions given below:
1. Go to https://products.office.com/en-gb/try?legRedir=true&CorrelationId=a8ae7f22-eda1-476f-b745-f9d432e40635 and choose the product you want to try.
2. Click on try one month free.
3. Login or signup using your Microsoft account.
4. Fill in your details and then install it.
5. After 1-month trial period instead of deleting or re-downloading go to the following path:
C:Program FilesCommon FilesMicrosoft SharedOfficeSoftwareProtectionPlatform and then click on OSPPSVC.exe so now your activation is re-armed. You can do it for five times excluding the one month trial.
So you can use it for 180 days.
If you want to download a trial version of Microsoft Office, here are some you can try:
Microsoft Office 2007 and 2010 – download from Microsoft Software Download. In early February 2015, Microsoft decided to finally discontinue the distribution of all ISOs on Digital River. Because of this you won’t be able to legally download offline or standalone installers of Office 2007 and Office 2010. The only way you can get a download copy of the two Office suites is from Microsoft Software Download.
Here, you will need to enter your product key to pull the qualifying Office product.
Microsoft Office 2013 – if you have 32-bit Microsoft Windows, download Microsoft Office 2013 Professional Plus 32-bit. If you have 64-bit Microsoft Windows, download Microsoft Office 2013 Professional Plus 64-bit. These two links will directly download the image file of Office 2013. This is the final version of Office 2013 which can be used for 60 days without restrictions.
Note before installing any of these trial versions: once the trial version expires, they will revert to reduced functionality, basically becoming mere file viewers. The only way to get them working again is to reinstall your operating system.
Notifications
