Download Ultimate Boot CD For Windows 7
What the contents of the ultimate boot CD for windows 7? What is the importance of this CD? Are these tools easy to use?
It is a bootable CD that contains tools for the Boot management, device information, Data recovery, Device management, Partition management, Memory, Disk Editing and wiping, and the computer BIOS. The CD has its own operating system hence you can use it if you’re Windows OS does not start. These tools are not easy to use as they are very powerful. It has a basic and confusing interface. It was created for advanced users.
If you are referring to the Windows 7 setup DVD, it is the most vital part so you can install the Windows 7 operating system on your computer. If you plan on installing or upgrading your operating system to Microsoft Windows 7, first, make sure your computer meets the requirements.
To install Microsoft Windows 7, it requires at least 1 GHz or faster 32-bit or 64-bit processor, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, 16 GB free space for 32-bit and 20 GB free space for 64-bit, and Microsoft DirectX 9-compatible video card with WDDM 1.0 driver or higher.
The Windows XP Mode in Windows 7 requires an additional 1 GB RAM and 15 GB free space. Since DVD discs may stop working in the future because of scratches in the surface, you can use Rufus to create a bootable USB flash drive.
This will allow you to transfer your Windows 7 setup DVD to your USB flash drive and install the Microsoft Windows 7 operating system directly from your USB flash drive.
