Hello expert, I need a help. Recently I downloaded Watermarking freeware from Bytescout. It helps to protect copyrights for my images with professional looking watermarks. But, on last night I saw an error “This application has failed to start to run on Windows because Bytescout. Watermarking. Cannot be found.” . Now I cannot use this software. Please provide a valuable solution to solve this problem. Thanks.
Download watermarking freeware from Bytescout
Hi Lorin,
The Bytescout watermarking software applies watermark to your image to protect copyrights. It is available free of cost.
If you have some problem to start the application, try to reinstall the software from the Bytescout website and check it.
You can also try Total Watermark software, masswatermark.
Hope this will useful.
There can be a number of reasons for the installed version of Bytescout Watermarking software failing to run. Instead of trying to fix the installation, you can download the portable (zipped) version of the same program, which does not require installation by clicking this link.
The download will begin automatically and once it completes, right click the archive and left click the “Extract to watermarking” option.
You will get a folder with the Watermarking software which you can then use without installation.
