Download a zip file of Mpman 959 play store
Hello, Can I download a zip file of Mpman 959 play store? Also I hunger a firmware for Mpman 959 plays. How can I perform Mpman 959 on google play?
Hello, Jerold Kramer!
You are experiencing problems when downloading.
If you have not updated your device, connect using WiFi and update. Because the Mpman 959 Play Store works with Android 4.0 and higher. If still can't download, you need to download manually the apk file.
Then copy it to your device, open the application manager and install it. If you can, set up your Google account, and it will upgrade automatically.
Enjoy the Play store.
To download manually, use this download link here.
Hope your question was answered and your problem was solved.
