Downloadable Outlook Contact Icq Exporter on the net?
Hello, John
Hope you are fine. Don’t worry. I think I can give you a solution. You do not need any software to download. You can do it easily on MS Outlook. Just follow the instructions.
Open the Outlook program.
Click the "File" tab, and
Select "Import and Export."
Select "Export to File," and
Choose "Next."
Choose "Personal Folder File," and
Press "Next."
Select the "Contacts" folder from the list of folders, and
Click "Next."
Choose "Browse" to save where you want to save the PST file.
Highlight the location from the list, and
Click "OK."
Enter a name for your exported contacts folder in the blank field, and
Press "OK." Select "Finish."
As you want to download , so there is link.
Hope you will get your answer.
