I am using Mac and recently downloaded Adobe PS CS5. Is there any way I can change the screen so that it would display the controls for Mac? When I went through the tutorial book for PS for Mac, it says that it would have the normal window controls. However, it is not in mine. I have Photoshop Extended. Can anyone out there help me?
lee hung
75 points
Downloaded Adobe PS CS5 and need to change screen
Hello Michelle,
I am trying to understand your question but it is like I am getting lost somewhere. Do you need the mac controls on your mac computer or you want to use the windows controls? In the first statement it is like you are saying that you want the mac controls, but in the second you are saying that the tutorial said that the computer will have windows controls but then it does not meaning that it has the mac controls. Which therefore leads me to conclude that you do not have a problem.
But you can just clarify the question more to make it easy for us to figure out how we can help you.
__
Regards
Lee Hung
