Downloaded SMPlayer 0.6.8 to install the Setup got this error
I have downloaded SMPlayer 0.6.8 but when I attempted to install the Setup I got this following non sense error. I can’t understand what is this? I have tried to reinstall the program but the same error appeared. Can I get some resolution? I would be grateful to you. Thanks.
SMPlayer 0.6.8 Setup
The binary codec packages add support for codecs that are not yet implemented natively, like newer RealVideo variants and a lot of uncommon formats.
Note that they are not necessary to play most common formats like DVDs, MPEG-1/2/4, etc.
