Downloaded songs in Rhapsody is invalid
I just bought 15 songs in Rhapsody store. After downloading all the songs, I instantly clicked it on my music list, but it says the file is invalid. I went back to the Zip file that I just downloaded and then right-clicked it to extract the file. After extracting, the songs are not there and the folder is empty. What can be the cause of this? What should I do next?
