Downloading and using crazy talk 4
Hi guys,
 I am a photographer and I was looking to adding some animations to some of my photos and I was looking for the best software for this, I have heard that Crazy Talk is the best software for this so I was wondering if anyone can assist me by telling me how I can acquire Crazy Talk 4 for windows 7.
Anyone who can help me on this please reply to this post.
Best Answer by Glenn Mcgaughey
Answered By 0 points N/A #158983
Crazytalk  is really one of the best software to use in adding animations in a photo today. I have a relative who is using this kind of software and seem satisfied with its performance. It lets you create animations and you can even add an audio to your work. But I suggest that you try the Crazytalk 7 which is the newest version. You can download the trial version from the link below:
https://www.reallusion.com/crazytalk/download.html
If you’re satisfied and decided to buy the full version, you can refer to the link below:
https://www.reallusion.com/store/product.html?l=1&p=ct
(You can also choose from the Standard version or go Pro)
Answered By 0 points N/A #158984
Hi Bolton,
A lot of versions have become available for Crazy Talk. Here is the download link Crazy Talk 4. It is a shareware program which you will need to buy but you can try it for 15 days free trial. I have heard a lot of positive reviews for this program but you may also check its review here for further details.
I hope this solution have guided you in your concern.
