I am trying to download some apps on my Samsung S4 Phone. When the installation is finished. I cannot locate any of the apps i download. I search for it on all folder and checked it in my app manager. Already restart my Phone. Where do you think it is?Â
Downloading Apps on my Samsung Phone
Edward,
Please try to use these two possible solutions
The files are saved depending on the type of it.
Try to do this to find them:
1. Go to settings in your S4
Click on storageÂ
This folder is organized depending of the type of file that you previously downloaded. Try to look for the files you need.
2. At the time that you downloaded maybe you save them on the SD card. Browse the card to check if they are saved there.
Hope this helps
Riley
