Downloading Arabic Template for Letter
I need an Arabic template for letter but I also need some advice on how I can embed it within an ordinary letter written in English. The template part will be introductory while the rest of the letter will be in English. Please, can anyone help me in this? Thanks.
Answered By 0 points N/A #159639
Harford I have solution for your problem:
1] First install Google input tool for Arabic language.
2] To create Arabic template for letter you can type letters which required in Arabic.
3] Google input assist you in the way, like you can type in English and it will translate in Arabic.
4] You can switch between language press "shift + alt".
5] You can write in Arabic as well as in English can create template using above technique.
Please check Google input tool for more details.
