Downloading Avira antivirus – The Package Is Broken
Asked By 120 points N/A Posted on -
While downloading Avira antivirus version 9, I received an error message. It says, "The Package Is Broken". I tried to download the same for several times but failed. How can I download Avira for my machine? Have you any idea?
Please help me to solve the problem.
Thanks for all solutions.
Best Answer by Greaney Mary
Answered By 0 points N/A #135650
Hello Judy,
You must remove the existing virus guard before proceeding with installing  avira anitvirus.the error is given due to this.So try it again like that.If you are having avira at the moment do not reinstall but try to update it to the latest version.If you have additional questions inform me via this forum.
Shenan
Answered By 10 points N/A #194964
Hello Judy Plum
Hope you are fine. You are trying to download Avira 9.There are 2 types of Avira9.Free and Licensed version. Which versions you are trying? Change your download location. Download from the different server like softwaretopic. It can solve your problem. You can download Avira9 offline installer. It helps you to set up Avira9 without online. Hope this will help you.
With thanks
Greaney Mary
