Downloading burger font letters for my windows 7
I have windows 7 and want to download burger font letters for my computer. I want to know if the burger font letters will support my pc. Please also tell me where can I find burger font letters.
Hello Daniel Kaffe,
Yeah you can download Burger Fonts for Windows 7. Download the Fonts, then Click on Start button and Type Fonts. Click on the folder Fonts which appears on the top. Now copy the files you have downloaded and paste in the Fonts folder.
Links for Burger Fonts:
http://www.fontspace.com/category/burger
https://www.dafont.com/cheeseburger.font
You can search for more on Google!!
As long as the font is in *.ttf format you should not face any difficulties to use it in your Windows 7 computer. There are number of website from where you can free download your desire font. Couple of websites are:
Yes Burger fonts are available for windows 7 and you can download it for fee. Burger fonts support windows 7 pc.
To download burger font click on the below link.
Steps for installing burger font:
There are two ways of installing burger fonts.
1. After downloading the compressed file extract the files to a specific folder.
2. Go to the extracted folder and double click on the files present in the folder.
3. A new window will appear asking you to install the font.
4. Click and install the font. This should be easy.
The other way is:
1. After extracting the files to a specific folder go to control panel -> Appearance and personalization -> Fonts.
2. Now just drag the extracted file in to the fonts folder. That will do it.
Hope this helps you.
