hello guys, please help me on how to fix this error. I don’t know if it is a bug since I already used the application for several weeks but no problem at all. I Got my opera mini dns error while I’m downloading a file over a wifi connection.
Downloading files got my opera mini dns error
If you encounter the problem with your Opera mini while doing a file download via a Wi-Fi connection, try closing the application then open it again. Try downloading the file again then see if it’ll be successful. If not, check if your Opera mini is configured properly. Or, you may simply try downloading other stuff instead of the file you are downloading to see if you are able to download other stuff.
If you are able to download other files then maybe the website where you are doing the download is probably experiencing heavy traffic that’s why you encounter the download error. Try downloading the file again after a couple of hours or maybe during off-peak hours to make sure the traffic in your network is less.
