I am trying to install BearShare software from the web but I keep getting this error message as shown below:
Downloading of Installation Data from the web has failed.
Please make sure you are connected to the internet.
Would you like to:
Try to resume the broken download?
Download a new copy of data instead?
If you choose Cancel, setup will exit.
However, you will be able to resume your download from where it left off when you re-run the setup.
Downloading of Installation data has failed in BearShare
Hey There buddy!
Did you try downloading the software multiple times and still getting the same error? Does the error occur to all files you want to download or just to Bearshare? Sometimes the problem is not your connection but the server itself, maybe the server is down or too many people downloading the same program at the same time.
Try downloading from http://download.cnet.com/windows/Â or www.filehippo.com for the free full BearShare software. After you tried this method let us know if it still give you problems or not.
Good luck
