Downloading from Nokia phone browsers
I connect to internet through Nokia browser.
How to open something which has been already downloaded?
Hi Charmaine!
Opening downloaded files from the Nokia default web browser is easy.
First open your web browser then go to Options then Downloads.
There you will see your downloaded files.
There is an another way top open your downloaded files.
Go to your phone's File Manager. Then browse the folders , you will see a folder dedicated for your downloads.
Click on that , presto! you can see your downloaded files.
I have another tip for you. Download Opera Mini Browser for Nokia. Just go to http://www.opera.com/mobile.
There you will have a option what to download.
Choose symbian then press download, after that install it to your device.
Opera browser have a tab for downloads which really helps finding your files fast.
Hope this helps
Alex
